daily_double's avatar
daily_double
Inverter generator
Do I need an inverter generator to run the a/c, microwave etc in my tc? why? Thanks !
  • Any generator with enough wattage will power an RV AC unit or any other items requiring 120 AC volts. Inverter based generators offer better fuel efficiency, quieter operation, cleaner power, and are smaller and lighter than the non inverter counterparts. They do cost quite a bit more initially which is why some choose to go with a non inverter version since they only use them sporadically throughout the RVing season.
    We do lots of RVing off the grid and purchased a Champion 3100 inverter genny 4 years ago, much quieter and fuel efficient than our Onan, it easily runs our RV AC unit with plenty of wattage to spare. Check your TC AC unit specs to determine wattage requirements, 3K watts is normally recommended for reliable operation at higher elevations.
  • Quiet.
    Inverter generators run at much lower rpm than non-inverter generators and since they are top-shelf items, manufacturers also put better mufflers in them.
    Side result is that they save fuel.
    I had 3600 W Generac in my older RV and it would suck 1 gal in 1 hr even without load.
    My inverter Honda 3000 will run on 1 gal for 6+ hr under AC load.
