marininn wrote:
The quick and dirty way to power outlets from an inverter is to use an extension cord with male plugs on both ends. Plug one end into inverter outlet and the other end into any camper outlet. This will power up the breaker box too and everything else, as well as the plug used to connect to shoreline. Electrical shock is possible if you touch the camper's male plug end. AND you will destroy the inverter if you forget to disconnect this and plug into shoreline. Like I said, quick and dirty.
* Another option is to use the Dirty method only, ONLY, to connect the ground and neutral wires. Use the home-made cord with two male ends to connect one to the inverter and the other to any plug, preferable one out of the way or hidden in the dark spaces. BUT, run the hot wire, black, as a bare wire and connect to the toggle A-B switch as described above. BE VERY SURE THAT THE PLUG CAN NEVER COME OUT.
Sometimes camper electricians do not follow code, so double check that the white and black wires are neutral and hot.
:E Please do not do this :E
