gpascazio's avatar
gpascazio
Inverter install
I am in process of powering all my outlets in my 2010 Eagle Cap 1160 with the Powerwattz 1750 inverter. My question is, if I turn off my Progressive Dynamics 9245 at the 120V electrical panel, will this prevent the (PD9245) converter from running down the batteries? Or is there something else I need to do on the 12V side?
Sequence of operation will be as follows:
Manually select off on the circuit breakers for the Air conditioner, the microwave and the converter (batteries and inverter not big enough for these).
select the "inverter" position on the manual transfer switch.
