lawrosa
Jun 28, 2016Explorer
SoundGuy wrote:hohenwald48 wrote:
One thing to avoid is powering the converter via the inverter. That will deplete your batteries quickly and may cause other issues.lawrosa wrote:
Not if you turn off the charging circuit.. It should be labeled on one of your breakers..
Is this not self evident? :R
No its not. Not if the response is to avoid powering the camper with the invertor.
My future mod is to add invertor and wire the outlet to another outlet under my camper.
This way when boondocking I can access all my outlets in the RV.
Simple plug the RV into the invertor..
When doing this if you dont turn off the invertor charging circuit the batterys will continue to try and charge themselves. And will soon be dead due to the eff losses.
