daily_double's avatar
daily_double
inverter question
So I'm going to remove my battery for the winter, but what do I do about the Inverter ? Do I just tape the wires up and forget it, or do I have to disconnect the inverter to keep from sending power to where the battery used to be?
  • I am removing because it's lithium and I don't have any way of heating it.
  • If it's just an inverter then just let the wires hang. If it's an inverter / charger you need ti disconnect it from AC power.
    If you have access to AC power you may as well leave the battery and let it float charge.
  • Depends. Is the RV plugged in? What is the make and model of the inverter?
  • Leave the inverter alone.
    Why are you removing the battery?
  • The inverter won't do anything once the capacitors discharge. If you are keeping it plugged in, leave the batteries in place.
