fpoole
Aug 31, 2015Explorer
2oldman wrote:fpoole wrote:Only the amperage draw of the appliances connected to it can overload it.
I wasn't sure if the "Strips" would overload it or not?
OK, that's where I get a little confused..
If the Inverter handles xxx amps output
I then total up the amps needed for each device plugged into the strip, allow for slight adjustments then I'm ok if it's under the Inverter amps output?
Ex:
Inverter amp output xx amps, all the devices attached to the strip can't exceed xxamps... xxx amps would fry it.
pure Sine Wave Power 300w
I see the "No load current Draw" but that's just idling I'm assuming, nothing drawing.
I was looking at one of the examples, but not seeing the Amp output levels to know...
