Hi All, Has anyone tried running their RV fridge on a basic inverter. In my case I have easy access to the plug on my fridge. I would disconnect the plug from the 110v outlet and plug it into an inve...
Do you want to use AC while driving for some reason? IF so then provided your Tacoma alternator is adequate for the job then install the inverter in the truck and run AC wiring to the RV. Adequate as per above it will be about an extra 30A draw.
