Hi All, Has anyone tried running their RV fridge on a basic inverter. In my case I have easy access to the plug on my fridge. I would disconnect the plug from the 110v outlet and plug it into an inve...
Why not run it on 12 volts if the fridge has a 12 volt setting? Inverting 12 volts DC to 120 AC takes power. Your batteries will last longer if you run the fridge on 12. If you only have gas or AC, I can understand why you want an inverter.
