JCR-1
Mar 09, 2018Explorer
Inverters Why ??
Why not use 12 volts for your camper. 12v items are more and more available today . Microwaves, a/c , will require a generator /or shore power anyway. TV 's are 12 volt, lighting and most everything e...
When you use an inverter the inverter itself without no load is a 10 -15 % loss in battery powerAre you estimating this? My inverter draws 1/2 amp when it isn't powering anything. I also have a Tripp Lite inverter that automatically shuts off when a load isn't present. My 1000W PSW inverter is rated at 96% efficiency.
