Thank you all - I have had enough feedback (across a few forums) that my initial fears have been correct – there is NO way my Half Ton Truck can pull a 5th Wheel safely (or at least within the limits of the given numbers).There has even been some feedback challenging my trucks capability of pulling a Travel Trailer.Can Half Tons be that far off when it comes to trailering (my Ram can’t be THAT much less capable than the others)?I see them all the time, out there doing their thing, with far larger Trailers than I am even considering.
Well to my fallback position, a Travel Trailer in the 32’ Range. This size Trailer is comparable to a 5th Wheel while keeping the general interior dimensions/floorplan.The Overall Length (Truck and Camper) is worrisome now - that is a considerable “Length” Penalty going to a Travel Trailer.
I had already mentioned the Keystone Hideout, which comes in at 31’-6” and a Dry Weight of 5610lbs and a Tongue weight of 840lbs. On the longer side there is the Jayco Whitehawk 30DSRE that peaks my interest.That one comes in at 33’-11” a dry weight of 5990 and Tongue weight at 585lbs.For some odd reason the Jayco while being longer and heavier has a lighter Tongue weight.While I listed just two, there are actually MANY comparable Trailer options from various manufacturers (give or take a foot).
So please, keep the feedback coming (Towing capability as well as target Trailer).
Curious - One reply stated that while a 5th Wheel might exceed the capabilities of the truck, it would probably tow better than a Travel Trailer falling within the Capabilities of the truck. Nothing is easy!
I have some time to work this out, so I will continue to follow the Forums for advice.
