illgild's avatar
illgild
Is a Gas 3/4 Truck and Pop-up Camper Safe in Colorado?
Hi all, this is my first post, so apologies if this is covering existing territory. I know the diesel vs gas question has been explored a lot here, but am curious if anyone has insight into the viability, and possibly specific model recommendations for a used gas 3/4 truck (roughly years 2013-2017 due to safety features) in Colorado hauling a pop-up camper like a Hallmark Cuchara or an equivalent Outfitter weighing in wet at about 2600lbs. From what I've seen, if I were on flat land, I'd go with a gas truck without question, but I have some concern, though no direct experience, about safety and handling in the mountains. Thanks so much for considering my question!
    Probably a 3/4 ton truck (whether gas or diesel) would not be a dully?
    A dually is the safest due to great side-to-side stability on curves and in high cross winds from it's wide rear tire track-width.
    Also, dually rear tires are safer for another reason - if one of the rear tires should fail while traveling it has a "backup" tire right next to it so you can slow down or stop under good control - or even maybe travel several miles on the one tire left in the dually set where the failed tire is.
  • The safety and handling will be the same as a diesel. But, gasoline trucks will probably go up the mountains slower. As you probably know, you lose HP with a nonturbo vehicle at altitude. Most passes have lower speed limits than the valleys. So as long as you don’t have an issue with having a lot less HP/acceleration, you should be fine with a gasoline engine.
    Fast Lane Truck on youtube does tests of hauling in Colorado for a number of vehicles. Their low weight tow tests would show you the difference between gasoline and diesels.
  • Drove all over Colorado in a gas 3/4 ton Chevy Cheyenne 4x4 truck and a Beaver camper including RMNP...12,000+ feet...without any issues.
  • Hi and welcome! Old rig was a 2500 Silverado 6.0 gas with an Outfitter Apex 8. No issues at all - and why would it? The truck can pull a lot more weight than it can carry. It will rev higher than a diesel and use more fuel, but it will be a lot cheaper to buy and maintain. No worries.
  • I live in the mountains on west coast with 2500 gas, carrying a Northstar 800. No issues with power, safety, etc.
