bighatnohorse
Sep 13, 2022Explorer II
It appears that the Aventa requires 230 volt 50 cycle. It maybe for European RVs.
The RecPro model i looked at is 120 volts but draws 14 amps.
And the RecPro specs state the db at 59 - about the same as a Honda 2000 generator.
The "standard" truck camper AC such as the one on my Arctic Fox draws 8 amps.
You'd pretty much need a 50 amp hookup if you're running a larger RV.
44,071 PostsLatest Activity: Aug 30, 2026
