79Salem
Oct 15, 2013Explorer
Is floor flex normal?
2008 Jayco 17c Ex-port, 200 nights since 2010.
Just inside door linoleum is floating loose from floor and floor flexs where it did not, before. Similarly, just after left turn towards bathroom and kitchen floor flexes on either side of a cross brace but linoleum is tight with floor. I've inspected under camper and inside access panel outside tub. No sign of water. Jayco service man has inspected, no water signs, either.
After repeated use and traffic is this what develops? Jayco service offered to do two positive pressure tests to see if there is a leak. When I asked what the fix is for a wet/rotted floor, if that is the case, they said none.
So, clean camper, no water sign inside. I'll go under and see if there is room to maybe jack it up and bold or weld in another brace.
