LarryJM
Dec 02, 2015Explorer II
mfoster711 wrote:
I think a lot of the replies have got a little off course from what my original question was (and I may have contributed to that).
To reword my question: The recommended hitch for my setup is the 10k hitch but if I slightly overestimate the amount of tongue or cargo weight then it starts to suggest the 12k hitch. I was wanting to know if there was any harm in getting the next size up "just to be safe" in case I do happen to load my truck and camper with this much additional weight.
The reply I got from Equalizer says this is 100% OK and they actually recommend getting the next size up if their is any possibility you might need it.
Realizing a lot of you are not talking specifically about the Equalizer hitch, I did some looking around and I also found this chart for Reese hitches.
This chart shows which hitch Reese recommends depending on your hitch weight. Based on this chart, there are two hitches you could choose for all hitch weight between 400-1500 pounds. From 1000-1200 you could actually choose between 3 hitches.
So in summary, when I take into account the reply I got from Equalizer and when I review this information from Reese, I would have to say it is completely safe to get the next size up if you have any doubt whatsoever that you might need it.
Is it OK to pull a popup with a 14k hitch? That is probably a different debate and is not what I really was asking.
Hopefully, but I doubt it, that chart from another MEGA hitch designer/manufacturer/player which is similiar to what Equal-i-zer is telling you about the myth that a WDH must be fine tuned to the actual current TW is just that mostly rumor and myth. In the past I have always thought going one size up was fine, but now would change that prior recommendation to include say a 1.4K/14K Equal-i-zer for tongue wts close to 1K with the only downside being it will be heavier and cost more. For me I still would not use or recommend something like a 1.4/14K hitch for a 600 or even 800lb TW. That is still just too far outside my personal comfort zone as to what to recommend to others as a NON EXPERT.
Larry
44,066 PostsLatest Activity: Mar 14, 2015
