marcarolle
Oct 28, 2016Explorer
Is it ok to use Spray Nine to clean Gray Water tank?
This week-end I'm planning to rinse off and clean up the black water tank, filling it with water using the https://www.walmart.com/ip/Camco-Flexible-Swivel-Stik/14504324Camco Flexible Swivel Stik
Then I will take the TT to the local RV dealer to use their dump station (all local CGs are closed around here).
I will fill up my gray water to clean up my sewer hose, as usual.
To do that, is it ok if I pour Spray Nine in the sink drain with water, instead of dish detergent? Contrary to dish soap, Spray Nine disinfects.
This will all be done prior to winterization with the pink RV plumbing antifreeze.
Any comments/suggestions?
Marc
Marc
