schlep1967 wrote:
Your camper does not have an alternator. It has a converter. It converts A/C voltage to D/C voltage. Yes the fan runs when it is working properly. You will notice that the more 12 volt lights or vent fans you turn on the louder the fan will get. Totally normal.
Ok, thank you.
I have all LED lights and I'll have the TV on in the evening but I'll hear the fan running all night when the lights are all out. I guess fridge is running.
My understanding is the Coleman TT needs a 12v battery for the AC to run, which it runs a lot in the summer. My feeling is the battery is getting depleted while I'm not using it then try's to get to full charge the 3 days it's plugged into the 30amp outlet.
Your help is very appreciated. I'm new to this.
