Gdetrailer wrote:
kilboar wrote:
MFL wrote:
A WFCO 8900 should be a 45 amp converter, which is a common size in other brands.
I don't think the 8900 has the ability to go to a float charge of 13.2, and plugged in 24/7 at 13.6, will cause fluid loss over time.
My battery rarely needs water, a couple times over a number of years is all, and converter is plugged in 24/7, for 8 months a year.
I have a 45 amp Progressive Dynamics converter with smart charge. I have never heard the fan run since new, but maybe it is super quiet, or my hearing subpar.:)
Jerry
Very appreciative. I'll give the company a call and run amps by them as well.
My other concern with leaving the TT pulled in 24/7 while I'm 4 hours away is if a storm knocks it out do I want a live wire on the ground?
Generally with good quality converters as has been discussed in this thread, you can leave your rig plugged in 24/7/365 and not hurt the converter or the battery (although sealed flooded lead acid, gels and AGMs might be a bit more problematic since you cannot check and add water as needed). With non sealed Flooded lead acid you may need to check the water levels periodically and add water as needed.
As far as storms, power outages and live wires on the ground goes..
Storms or power outages should not be much of an issue, when power is restored, converter will automatically recharge your battery. Prolonged outage like a week or more could shorten the life of your battery by allowing the battery to discharge and run dead.
Live wire on the ground?
Your shore cord is designed for outdoor use, it will be fine laying on the ground even if it gets soaked. It is not however under ground rated and should not be buried directly or in conduit or pipe.
If concerned about the shore cord laying on the ground while un attended, I would suggest buying some direct burial rated wire, ditch it and run that to your power source and to a wet location box at your RV where you can put a outlet for your RV.
Thank you,
I am running an outlet next to the TT now so no vehicles will be running it over.
By "live wire on the ground" I meant if a hurricane flipped the trailer over and cut the cord off but I suppose if thats the issue the power is already out or it throws the fuse at the breaker box so none issue.
