temccarthy1's avatar
temccarthy1
Is my battery toast?
I have a 6 year old deep cycle battery for my TT. Has always worked fine even though we are always hooked to electric when we camp.. When I pulled the battery a couple weeks ago when I winterized the TT and put the battery in my garage to charge it ( haven't used the TT for several months) I noticed the water levels were low in several cells and the plates were not covered on 3 of the 6 cells . I added distilled water and filled them. On the charger I noticed it is making a bubbling noise and the battery is warm. Is this battery toast? Did the water levels get too low and the almost half gallon of water caused damage? Or am I kidding myself with a 6 year old battery?
  • Dennis12 wrote:
    Its shot after 6 years. You sound like my wife. She tries to get two months out of a stick of gum. Time to spend.
    For a second there, I thought you meant your wife was shot after six years. :B
    Seriously, she should last a lifetime. :)
  • Exposed plates means sulfation. I would charge it until it stops taking it, then have it load tested. But it's most likely shot.
  • OP here...Thanks for all the replies. I tried charging it for a full day but the charger circuit break flipped. The great majority of you are correct--it is apparently shot! Will replace..
  • And if my TT was in winter hibernation, I would not replace it now.
    Just wait until spring when you are going to awaken your TT from it's long winter sleep.
    Unless you plan on using it during the winter, of course.
