jbres's avatar
jbres
Is my Cat.Converter going bad?
I have a 2003 Tahoe with 132,000 miles on it. I have always had slight weird "muffling" noise through exhaust system during heavy acceleration. It has gotten worse now, and during acceleration, I have a weird "rattling" "muffling" noise traveling through my exhaust. It idles perfect with no exhaust noises if you stay idling.
I got under it and through visual inspection, my exhaust is in good working order.
Is it my cat converter gone bad?
Other ideas?
  • also, my check engine light is NOT on, so if it was the Cat converter would my service light be on?
  • so when a baffle comes loose do I need to replace my entire muffler?
  • Sounds like a baffle came loose in your muffler, a common issue in a vehicle with that many miles. When a cat plugs up, usually you will have a hissing sound and no power at all.
