bimbert84
Sep 02, 2013Explorer
TucsonJim wrote:Towing a travel trailer is very, very different than towing a cargo trailer. When cruising down the highway, aerodynamic drag has far greater impact than weight on your ability to pull a trailer. You have to consider frontal area. See page 15 here:I just verified that the 2008 six cylinder Escape CAN tow up to 3500#. I'm not sure why folks are telling you 2000# when the Ford engineers designed it for more.
http://www.ford.com/assets/pdf/towing/07RVTTgdeMay07.pdf
Note that the Ford Escape is rated at only 30 sq. ft. of frontal area, assuming you have the V6 (it's only 24 sq. ft. otherwise). That's only about 7' across by 4' tall, or in other words, a pop-up. Most travel trailers are at least double that.
I agree with the others: the Escape is nowhere near up to the task of pulling even a small travel trailer.
-- Rob
