BarneyS
Jun 19, 2018Nomad
IdaD wrote:
Snip... At the end of the day the FW is still a lot heavier on the pin and the hitch point is over the axle versus 4' back, and no TT hitch is going to change those facts. Snip...
I will agree that the FW is a lot heavier on the pin but will dispute your statement that no hitch is going to change the fact that the hitch point is 4' behind the trucks axle. The Hensley hitch DOES change the results of that fact! Due to its' geometry, the pivot point of the hitch is projected to just a few inches behind the axle or in front of it. This fact allows the travel trailer to tow just about like a FW because the attachment point of the trailer is now felt by the truck right about at the trucks axle and cannot influence the direction of travel. The hitch also restores the lost weight from the front axle via the spring bars and jacks so the steering of the truck is like normal.
I have towed both 5th wheel trailers and regular trailers for many years and have used a Hensley for the past 10 or 15 years or so. I can testify that the Hensley hitch DOES make a trailer tow as well as or even possibly better than a 5th wheel. I say better because the TT is lower and has less leverage above the CG of the truck than a 5th wheel. It just feels more steady and stable.
Barney
44,056 PostsLatest Activity: May 04, 2014
