JRscooby
Nov 05, 2021Explorer II
Grit dog wrote:JRscooby wrote:
Every time I see a discussion about exhaust brakes I have to wonder if there has ever been a comparison of the whoa power of like sized diesel w EB/gas with closed throttle. (I know I nearly died the first time I expected a 855 CID Cummins without Jake to hold me back as much as 427 GMC did)
Unless it can be shown the exhaust brake ******* a lot more than the throttle plate, slick roads with it on would be no more dangerous than gas engine.
Idk about any of the GM L5Ps or the newer Powerstrokes, and it feels like you’re just fishing for a response to reply to about how these “little” pickups aren’t “real” trucks like you the pro truck driver, drive.
No, I have always owned light duty and heavy duty trucks. And a good percentage of the time I had medium duty. Back when I bought my first class 8, Ford, GMC and Chevy where all selling class 8s with spark plug engines. If I could of made a living driving no more miles than the average RVer puts on their rig in a year, I would of parked a 427 GMC the day I retired.
But I can assure you that both the aftermarket in-line brake I put on our old truck and the turbo brakes on the newer Rams have significantly more whoa power than any of my gassers, even the 10 speed that drops 3 or 4 gears when descending a hill with a trailer pushing it down the hill.
Yes, a EB works. I retro fitted 2 3306 Cats and a M11 Cumapart, and they all would slow the vehicle better than the little GMC. But if my memory/math are close, I'm comparing them to about 7 L engine.
A compression engine, speed and power is controlled by fuel flow. Unless something is added to it the only whoa is friction, air can freely flow thru. OTOH, spark fired, speed and power is controlled by controlling air flow.
Cummins12V98 wrote:
UH YEA, I towed 34k combined with my 15 down several miles 14% grade locked in 2nd gear not touching my brakes. I thinks me EB works just fine!!!
The Friday before the Monday I nearly died, I pulled up out of the pit, grossing 110,000 Lbs with the GMC in 1 and 1, (Yes, for that 1/2 mile you had to drive a stake in the ground to tell I was moving) When topped the hill, start down, shift aux to 2. When get down that 1/4 mile long grade, without touching brakes, I was doing walking speed when pulled on scale. Monday, with the Cummins, same load, climb hill in low, shift up to first at top (13 speed Road Ranger) realize I had to stand on the big pedal hard all the way down, could not stop so turned out into the parking area.
