Bull_Rider
Apr 25, 2014Explorer
Just to check your procedure, you're attaching the sway device at both ends, and then tightening the hand crank fairly tight? There will be a little wiggle until you compress or tension the device. It should then be fairly snug. If it's not under compression or tension is will feel a little loose.
44,066 PostsLatest Activity: Apr 10, 2026
