grovegang52ExplorerApr 25, 2014Is the friction sway unit supposed to "wiggle"?After the friction sway is locked onto the balls is the whole unit supposed to be really loose? It seems that there is an awful amount of movement when I grab it and shake it. Thanks for any advice!
usmc616ExplorerApr 25, 2014When we used a friction sway control device it always had some movement when hooked up properly.
Related ContentJust SupposeFantasizing, I supposeFriction hinge fixFriction Sway BarAnti-Friction Lubricant
