agesilaus
Dec 17, 2018Explorer III
* Expensive injectors (routine wear item)
* Expensive HPOP, Fuel Pumps, Lift Pumps etc.
* Expensive Batteries X2
* Expensive particulate filters that will need to be replaced at some point.
Not on my truck which is almost 6 years old. The fuel pump issue only occurs if you get water in the fuel. Injectors are not normal wear items. I just a month ago replaced the batteries on the truck at 5 1/2 years. And I don't have any idea what the so called expensive filters are? Fuel filters? I believe gassers have fuel filters too.
