mleekamp's avatar
mleekamp
Is this a can of worms?
Okay, A friend with 3/4 ton Dodge noted my 1500 (half ton) has too little tow capacity. True, there is a difference, I don't argue that at all. But look at this...
in 2000, I had a 2500HD Chevy with a 10k tow rating (WD hitch)
in 2005, I had an F150 with 9500k tow rating (WD)
today, I have a 1500 GMC with a 9700k tow rating (WD)
I also currently have a 1979 Chevy with a 5k tow rating (WD).
My point to my friend is that over the years, the 1500 has become what the old 3/4 ton trucks were...they evolved. I keep within my tow rating no matter what, but am I correct thinking the half ton trucks have double capacity than what they used to?
Remember the 1500HD's? Ford even had F250 and F250 Super Duty (before it became just the SD model).
What do you think?
  • You can hit over $60K for a F150 King Ranch with all the whistles and bells. That's a lot of coin for any truck, let alone basically a grocery getter.
  • mleekamp wrote:
    What do you think?
    I buy 1 ton's to avoid being concerned about towing issues concerning what we tow.
    Last week I saw a 2013 Ford 1/2 ton truck on a dealers lot that listed for $55K+. A 1/2 ton!!!:E Anybody pay's close to that kind of $'s for a 1/2 ton should get exactly what they deserve; A $50K pine straw hauler 2X4 pickerupper grocery getter soccer momma/daddy gasser.
    Remember...you asked. JMHO.
    Happy camping!!! See y'all down the road!!!:)
  • My 2012 Silverado 1500 had a payload capacity of 1,550 pounds. My 2013 Silverado 2500HD has a payload of 3,040 pounds. Therein lies the difference. If you decide to tow a 9,700 pound trailer with your 1500, you will be dangerous and disappointed. No, I cannot explain why manufacturers overstate the tow ratings of their half ton models. Sales, maybe?
    I do agree that today's half tons are more capable than those of thirty years ago.
  • I think you can never have too much truck for safety and reliability.
    Towing an 8000 lb trailer with a 1500 and then with a 2500 or 3500 provides greater stability during unusual conditions and situations. Curvy mountain roads, extreme stops, wind/weather, long and steep grades or downhills, the more truck the better.
    I started out with a Dodge Ramcharger, moved up to a 2500, then a 3500 and now have a 4500. I have never felt safer or more confident when towing now that I have the 4500. No more white knuckles on long steep downgrades or in panic stop conditions.
  • MOST rigs today have more tow capacity than they did when I first bought a new rig in 81. An 8 lug 2500 came with typically a 300CI I6 with maybe 105-110hp and 250-300 lb ft of torque. A BB had 200hp and just over 300 lb ft of torque. Today std motors in an 8lug rig seem to have 250-300hp, and mid 300 lbs of torque, with diesel options of 300-400hp and upwards of 800 lb ft of torque. Since tow capacity is more or less based on power, yes, ANY rig today has more potential than in the past.
    BUT< one still has to deal with what the chassis can handle, or how much payload you have to work with. Even then, a typical 8lug rig has more payload today than they did in the past, so again, more potential for the ability to tow a higher wt trailer. This is also true of the 5 or 6 lug half tons too. Even the mini trucks have motors that are bigger and better than the 76 toyota I had back in HS.
    I do not know what you are towing, I have my own personal limits to tow with a given truck. It is not what the manufactures rate things at. SOme cases I am lower, others higher. I'll personally go to about 2x the GRAWR of a given rig. I find that over this amount, the trailer starts to wag the truck per say in some instances. So for a typical 8 lug 2500, with a 6100-6800 RA, that is about 12-14K lbs of trailer. SOme are rated to over this. One can pull over this and be safe! That is just my personal limit. I would have no issues pulling that with todays SB8 motors either. As the trannies are better, motor stronger etc than BB motors of yor!
    Marty
