riven1950 wrote:
...I think I did ok changing the tire...I used a floor jack with several blocks of wood on the frame to lift it enough to get the tire off. Also had two jackstands under the frame just in case while I went to the tire shop. To get the aired up tire on I used a bottle jack with a block under the spring bracket, to get the final lift, to get the tire on....
Do you carry all that on the road? It is best if you do all your home service with the equipment that is available when you are traveling.
I pay for ERS, but I still try to be capable of taking care of myself.
