Polishnurse
Mar 08, 2014Explorer
I be-leave you might be looking at the AC Condenser, chances are the transmission cooler is built into the radiator. You should see two 1/4 or 3/8 lines going into the bottom of the transmission if this is the case, that would be your transmission cooler.
I have on occasion used a condenser out of a an old air conditioner as a cooling cooler for the transmission, to provide added protection of the transmission should the radiator over heat. You would probably do best by have a garage or mechanic check it out for you. Just my two cents worth.
44,056 PostsLatest Activity: May 04, 2014
