jlrosine's avatar
jlrosine
Bypass radiator/tranny cooler combo?
Hi all. I have a 2005 Yukon XL Denali and wondered if anyone else has had success doing a radiator bypass for the tranny lines, and just using an Aux cooler on the front?
Issue 1: From the factory, GM and other manufacturers run the transmission lines through the main radiator and it shares space with the antifreeze (separated internally). If anything internal cracks inside the radiator...bye bye transmission. This has happened to quite a few people and seems absurd to design it this way.
Issue 2: The radiator/thermostat want to operate at 180 degrees. Why in the hell would we want to heat the tranny fluid to 180 then try to cool it again in a tiny little cooler on the way back to the tranny?
It seems to me that the best solution would be to just bypass the big radiator, thus reducing the risk of blowing my transmission if the radiator leaks/cracks/mixes antifreeze in my tranny fluid. Then I would need to install a larger aux cooler on the front to make sure temps stay low.
Is there a downside I'm missing to this? I know that some people think the reason it's designed this way is to actually heat the tranny fluid up on cold days, but given that it wrecks my towing and temps in the mountains, I think I'd rather just disconnect.
