JBarca
Jan 21, 2017Nomad II
tim1970 wrote:
Wife and I are considering the Jayco 32TSBH or 32RBTS which means a 36 or 37 foot TT. I am curious if it will be possible to pull this length without any sway issues? TV will be a 3/4 ton diesel and I would be willing to get whatever hitch necessary to prevent sway. (If such hitch exists)
Thanks
Tim
Hi Tim,
Our camper is 33' 6" tow ball to rear bumper. I looked up those 2 floor plans, you either did a typo on the 32RBTS or Jayco had that one not on there site. I found a 33RBTS though which I think is what you meant. Jayco 33RBTS
I also want to congratulate you...:C You have been trying to research this and you even went and weighed your truck empty to know real world numbers before buying. WOW. Your truck weights
I see you have the 2016 F250 Diesel. Nice ride! And I see you have been doing the math trying to fit a 5er into that payload. You have a good handle on your weights and your truck.
I'll give you some of my thoughts and how I came at this same situation. In our case, our camper weighs 9,950# loaded with a 1,600# fully loaded tongue weight. I have the F350 gasser. In our case the F250 with the diesel would not work as I would be out of payload with our camper, the way we camp and when I would add a truck cap to the back. The Diesel which a pulling monster, eats up payload.
In your case you have 10,000# GVWR with a 8,180# GVW. Your rear axle is 3,260# against a 6,100# GAWR-RR. This leaves you 1,820# on before GVWR and 2,840# before GAWR-RR.
Since you are looking at bunk houses and have a crew cab, that sounds like kids. At first pass, depending on what "stuff" you put in the truck bed, your GVWR is on the radar. Everyone has their stuff they take. In our case I have 500# of "stuff" that lives in the truck bed and this is with no truck cap. So I went the F350 SRW route to gain more cargo capacity and the gasser gave me a little more payload too.
Point I'm looking at the truck is your total rig. When you get to 36 to 38 foot campers, the truck has to be right, the WD hitch has to be right and the camper tongue weight to TT GVW balance has to be right.
I use the Reese DC. I have 16% loaded tongue weight on the TT and I also have rear helper springs (overload springs). Does your have rear overload springs? Some F250's do, some don't. Reason for asking, in our case those overload springs when I load the bed and adjust the WD, the overload springs just kiss the frame hangers and that create a much more stable towing rig. They sort of act like a rear sway bar. Does yours by chance have a rear sway bar?
Now the trailer. Heads up on these. Jayco is counting on you to load weight in the camper. I can tell by the weights of the camper, they are trying to control how high the tongue weight is going to go.
On the 32TSBH they have a 9.6% dry tongue weight. 815# TW on 8,520# dry weight (empty camper). The heads up is, you need to get that tongue weight up higher for more protection against sway. Ideally get this up to 13% or more with that 36 footer. Which is not that hard to do with the front cargo hole and bedroom. Just watch what you put in the rear wall storage as that will reduce the TW. If you load the camper to the max, of 10,950, 13% TW is 1,424#. More TW helps the stability, but the truck has to carry it.
On the 33RBTS they have a 10.1% dry tongue weight. 865# TW on 8,530# dry weight (empty camper). Same heads up here, empty you are sitting on the bottom end of good TT weight balance to the tongue weight. And on 37' 8" long camper, the TW balance needs to up higher. Again load the camper to get it up in the 13% and above area.
The camper and the 1,400lb area tongue weight will affect the truck. The WD hitch is a must in my opinion with these weights and camper length.
Next comes the anti sway. The Reese DC offers 1,500# and 1,700# WD bars. I "think" your truck receiver can handle those but check or you need and upgraded receiver. And your loaded tongue weight may be above the 1,400# number. In my case, I could not use a Hensley or ProPride WD hitch as they are only rated to 1,400#. The other choices were Reese which I prefer in the ultra friction type of hitch or a PullRite which offers up to a 2,000# TW. Pull Rite 2K TW hitch
The Pull Rite is the best bumper pull WD and anti sway hitch out there in my opinion. The pure mechanical concept it works on is very solid. It does however have 1 drawback, in non WD mode it is only rated for 300 to 500# pending which turck it fits weight carrying. Since I tow other trailers then the camper, and even some with WD, that low weight carrying rating was a hard one for me to get past. And, this hitch adds weight to the truck. I do not recall how much, 300 maybe more pounds.
My setup with the 1,700# Reese DC, the 15 to 16% loaded camper and F350 when setup correctly, does a good job but I did have to work through some adjustment as it was not a slam dunk. I get no movement from semi's passing or high winds (30mph) but the rig in not invincible. I have only had 1 time when extreme winds broke the DC loose from holding the truck. They were for sure above 30 mph, may have been 45 or more mph I had no reference.
Truck tires also play in this setup and the wrong tires can be bad news when towing long campers. More on that later if needed. But the OEM Continental Contrac TR's work well.
If I was going to tow 37 feet, I would seriously consider the Pull Rite and figure out how to deal with the low weight carrying rating. This is based on my towing background and knowing the good and bad of the Reese, we also do a fair quantity of towing (~ 5K miles a year). You are right on, for asking about towing that long of a trailer that has that much weight on a TT. Open flat beds are a different story then a TT.
I had some time today to type, so hope this helps give you a perspective to research further to come to a good decision.
John
