Thanks for all the replies, I was looking at getting the lifelines and almost pulling the trigger, but these blems (don't come with handles) caught my eye , anyone have any experience with DEKA's? Sounds like a pretty good deal, was thinking of getting 3 of them and putting one behind the battery compartment in my WC,
Limited unit's MSRP $328.67 for only $129.99 exchange (if no core + $28.00 core charge)
Hurry when they are gone they are gone **Very limited stock***
*** All have threaded studs***
12 Volt - 105 Amp Hrs - Group 31
Sealed Maintenance Free Deep Cycle Batteries for Marine, RV, EV (Electric Vehicle), Golf Cart, UPS, Inverter, Solar Panel (Photovoltaic), Telcom, CATV and Stand-by Applications
The Deka 8A31DT (8A31DTM) is an American made AGM (absorved glass-mat) deep cycle battery.
The AGM technology allows for a completely sealed maintenance-free battery with no sulfuric acid leaks, no acid clean up, and more power in the same space when compared to conventional batteries. It has an under 2% per month self discharge rate.
These are manufactured by East Penn Manufacturing who also makes batteries for MK Battery.
The Deka 8A31DT (8A31DTM) is a direct replacement for any group 31 lead-acid, GEL, or AGM batteries.
Deka 8A31DT AGM Battery Specifications:
Nominal Voltage: 12V
Amp Hour Capacity @ 20 hr rate: 105 a/h
Reserve Capacity @ 25 amp discharge rate: 210 mins
BCI Group Size: 31
Marine Cranking Amps @ 32* F: 1,000 amps
Cold Cranking Amps @ 0* F: 800 amps
Weight: 69 lbs
Length: 12 15/16 in.
Width: 6 3/4 in.
Height: 9 3/8 in.
Terminal Type:Stud Terminal
