palmwhit's avatar
palmwhit
It's time to replace airbags, Firestone or Air Lift
Have a leak in R/S airbag (Air Lift). It's time to replace as they are almost 10 years old. My local dealer recommends Firestone. Even though I've got good service from the Air Lift's that are on the truck I'd like to hear what you guys have experienced as products change over the years. I don't use or want the on board compressor.
I carry a Lance 1181 on a F350 DRW 4x4 crew cab. Thanks for your help.
  • I have started to use the Hellwig kit with great success. They are inboard from the spring pack, larger diameter and use less air pressure. Michigan Truck Spring has great pricing on them as well.
  • I used to work on large rotating equipment that used airbags to lift machine for some of its cycles. Every piece of equipment used Firestone airbags. I don't think you would be wrong to choose Firestone.
  • I have the air lift bags for 7 years without problems. I also have on-board air and wouldn't go any another way. It is very convenient because I'm always removing the camper when i get to my camping spot. My truck rides like a rock if the bags are aired up with no camper on it.
