IBcarguy
Mar 04, 2016Explorer
If you end up using a jack device, don't attempt to jack up the trailer by lifting it from the axle. Most trailer axles are tubular and lifting can easily bend an axle tube. Lift from a spring shackle or something, not the axle tube itself. A friend of mine did this and ended up replacing an expensive axle.
44,066 PostsLatest Activity: Mar 14, 2015
