JIMNLIN
Mar 04, 2016Explorer III
IBcarguy wrote:
If you end up using a jack device, don't attempt to jack up the trailer by lifting it from the axle. Most trailer axles are tubular and lifting can easily bend an axle tube. Lift from a spring shackle or something, not the axle tube itself. A friend of mine did this and ended up replacing an expensive axle.
Actually jacking from the axle tube on a std leaf spring suspension next to the U bolt won't bend or crush the axle tube.
I use a 12T shorty hyd bottle jack under axle tubes on my RV trailers/enclosed/equipment/flatdeck trailers/cargo/stock trailers. This way I'm just lifting one end of a axle just enough to change a tire.
Whatever method you use make a dry run at home. Some folks with the ramps found it didn't raise the flat tire off the ground or not enough to get the spare on the lugs.
44,066 PostsLatest Activity: Oct 04, 2013
