notsobigjoe wrote:
I had a set of the same jacks on my coachman ranger bu they were called hijackers. Two things did what your describing, low oil and the shaft needed a some new rubber gaskets. Probably not low oil if there is no evidence of a leak but if you never checked them or it's been a while maybe. I'd replace the oil if not leaking and get some new rubber seals. Also the cold affects hydraulics some what. Good luck!
Joe
similar to the set I had but much much older.
https://www.riecotitan.com/hydraulic-camper-jacks/%20Four-Corner%20Mount%20Hydraulic%20Camper%20Jacks%20White
These are the gaskets I'm talking about. I replaced them and they were
like new.
https://youtu.be/5DwpvUwohYA
https://hijackercamperjacks.com/
Sorry if they're not the same...
Thanks for the insight. I'll check the oil to see if that is a portion of the problem. I intend to rebuild them over the winter. I am sure the fact that the highs are in the 30's right now is a portion of the problem. It is likely impacting seals or oil in some way. Better to happen here than somewhere else.
Maybe it will have to stay on until I get those jacks rebuilt. Not the end of the world and a better solution than dropping it trying to get it off.
