Baja_Man
Sep 29, 2022Explorer
MFL wrote:
No need to lift a bunch on frame. You only need to lift axle an inch, with a bottle jack, or floor jack.
I have a 2x4 piece of oak, about 8"s long, with a da-do in center, that just cups a U-bolt. This works great at home, using a bottle jack under it.
I also use my Trailer-Aid plus, which will lift front or rear tire high enough.
Using some boards cut and stacked will work too, best if on solid surface.
Hooking to vehicle is a good choice, adding stability!
Jerry
Does that Trailer Aid Plus work on leaf spring axles? I read on manufacturer site that it does not.
Do you have a pic of the wood piece you use with bottle jack?
Thanks
