MFL
Sep 30, 2022Nomad II
Baja Man wrote:wanderingbob wrote:
Hitch up , pull up on blocks , work on the two axles that are off the ground , repeat for next set of axles .
Rolling up on blocks would be same as the Trailer Aid Plus plastic ramps. Only work on Torsion axles.
Do the blocks you have used under one wheel actually raise the adjacent wheel?
While mine is a FW with 5,200 lb axles, the suspension looks similar to yours. I have used my TrailerAid plus to easily lift and service all four wheels.
Jerry
