Baja_Man
Sep 30, 2022Explorer
MFL wrote:Baja Man wrote:wanderingbob wrote:
Hitch up , pull up on blocks , work on the two axles that are off the ground , repeat for next set of axles .
Rolling up on blocks would be same as the Trailer Aid Plus plastic ramps. Only work on Torsion axles.
Do the blocks you have used under one wheel actually raise the adjacent wheel?
While mine is a FW with 5,200 lb axles, the suspension looks similar to yours. I have used my TrailerAid plus to easily lift and service all four wheels.
Jerry
Jerry,
Thanks for sharing! Good to know that the Trailer Aid Plus works with leaf spring axles. I think I'll try that option first, as it is simple and easy. If it doesn't work, I can send it back and use the bottle jack method.
