MFL
Sep 30, 2022Nomad II
I use the bottle jack at home, where my FW has it's own concrete pad, next to driveway. If I'm going to pull the hubs, that is best choice.
To adjust brakes, or just using EZ-lube to grease, staying hooked up, using the TA-Plus is the bomb! Gets things done quickly, and nothing in way for brake adjusting.
I changed one flat, on side of interstate, with truck traffic, using the TA-Plus. It paid for itself right there!! Job done quickly, and out of harms way in 20 minutes. No issue lifting flat tire.
I read one review, stating the TA-P would not work. Always a nay sayer for everything! I could see a possible issue, if a tandam axle, and the wheels being WIDE spread??
