Baja_Man's avatar
Baja_Man
Jacking/Lifting Trailer for Wheel Bearing/Brake Service?
Hello-
Preparing to complete bearing service in the next few days.
Read owner's manual and it states, "Position a hydraulic jack on the frame close to the spring hanger."
I've also red of others using bottle jacks directly under axle U bolt shackles; perhaps their owner's manual suggested this.
When jacking, I would chock opposing wheels and may even attach tow vehicle for added support.
I have a tandem axle leaf spring set up, with an equalizer between each set of springs.
4400# AL-KO axles. My axles are BELOW leaf springs.
My frame has an underbelly cover and the frame is not completely exposed, (about an inch is exposed on outside edge), and rear axle hangers are several inches in front and about 15" at rear of where I could jack at frame (due to obstructions one frame).
Are there other SAFE options?
NOTE: The trailer will have to be lifted and supported for a few days while I work on bearings/brakes; one side at a time.
Also, where should jack stand be placed? This is not mentioned in owners manual.
What about those plastic wedge aids that you drive trailer onto? I've read mixed reviews about their ability to raise adjacent wheel off ground high enough to remove a flat tire. Read that they are only good for torsion axles and NOT for spring axles.
I can also make set of wood wedges using cut sections of 2"x6" that would work the same way as the plastic ones....but this may not work since the plastic ones appear not made for leaf spring axles.
Also, found this.... Bottle Jack Buddy
My jacking goal is to jack up at home and on road safely. Jacking would be for... changing a flat tire, servicing bearings and brakes, or performing other axle/spring work.
Thoughts?
Thanks!
  • Hitch up , pull up on blocks , work on the two axles that are off the ground , repeat for next set of axles .
  • Least effort and lowest point is from under the u bolts. Only have to Jack it up a tiny bit to get the wheel off. Vs having to potentially block up from your jack to reach the frame and then having to lift much higher to unload the suspension.
  • klutchdust wrote:
    There was a post about this recently that was rather amusing. it drifted off to the point of questioning what the poster knew about floor jacks themselves. Look it up.
    This ONE?
  • I believe in following the manufacturer’s recommendations.
  • There was a post about this recently that was rather amusing. it drifted off to the point of questioning what the poster knew about floor jacks themselves. Look it up.
  • Our Airstream has a small aluminum square behind the axle to mark the jacking point.
  • This has been beat to death multiple times here....
    Cliffs notes: It's fine to use the frame, near the spring perches. It's fine to lift the axles from the u bolts.
    It's fine to use any means of ramp/wedge/thingy to drive up on.
