Boatycall
Oct 10, 2015Explorer
TN Sportsman wrote:
If I went with Atwood electric, do you have to re-drill new corner brackets or are they designed to be used with the existing ones?
Each Mfg has it's own mounting setup, so this could work to your advantage - the holes you have in that corner are pretty shot. Redrilling into less damaged wood and remounting would be a good alternative.
44,056 PostsLatest Activity: May 04, 2014
