Bedlam
Oct 11, 2015Moderator
After fixing the wood with epoxy, you could add aluminum angle on the outside before bolting up the jack to strengthen the corner. If you can reach to the inside of the frame, use through bolts instead of lags. You may even have room inside for large nut plates or fender washers.
44,056 PostsLatest Activity: May 04, 2014
