TN_Sportsman's avatar
TN_Sportsman
Jackknifed trailer into TC Jack!!
:oWell as I was preparing for our maiden voyage with my "new" TC, I noticed that the extended hitch for towing my 18' G3 was not quite extended enough. I did some maneuvering in the driveway, and determined that I would need to get a longer hitch. But since I was all loaded up, campsite awaiting, etc., I figured I would be ok as long as I stayed away from really tight turns. Well that was true until the last day when I loaded up, and got going down a 2 lane highway and had to make a U-turn:S. Yup, it was just enough that the boat got into the rear jack and pulled the lag bolts away from the frame. I was so p!$$ed at myself because I knew better!!:M The damage is shown in the pics below.
Upon the removal of the jack and brackets, I believe I can fix this. It looks like the corner frame is possibly a 1x2 or 2x2? The wood appeared to still be pretty solid, but it did split somewhat when the lag bolts pulled loose. It did seem to go back together pretty well. I'm thinking that I can get one of those epoxy wood repair kits and inject it into the cracks, lag bolt holes, and fill in the void areas. I think I could get some slightly longer lag bolts, re-arrange the hole patterns for the top (larger) bracket. The lower (smaller) bracket does not have much left to grab to. It does not appear to be the load bearing bracket, so I think I could rebuild the void area with the wood epoxy, and weld a small triangle piece to the bottom (where it would "cup" the bottom corner), and put in longer lag bolts.
This has made me sick, especially because I knew better. Any thoughts/suggestions to my idea?
  • Kayteg1 wrote:
    Looks like bottom had some dryrot even before it happen.
    I work with epoxy quite a bit.
    What you might want to start with is "laminate" the damaged wood.
    Home Depot is selling boat epoxy, what is epoxy in its original form and also packs of fiberglass cloth.
    99 cents store sells cheap painting brushes, so get a dozen of them and get plenty of rubber gloves.
    If you don't have experience with epoxy -start on scraps.
    You will have 10-15 minutes working time before epoxy starts to set, so you need to know precisely what you are doing.
    Soak the damaged wood as much as you can.
    Once the epoxy sets, you can apply first layer of fiberglass over the wood and plan on doing 2-3 layers. Likely you will have to pull some siding away for it.
    Yea, I thought about the fiberglass option, but was afraid I might screw it up. The thin siding seems near impossible to pull back without damaging it because it has been glued to a layer of luan. Your right that bottom bracket was the worst. It gets all of the road water from the rear tires, and the rear skirt area is nothing but exposed OSB! I can't believe they don't seal it up. I'm pretty sure that bottom bracket is just for side-to-side support and not load bearing means they drilled one of the two screws sideways through the bottom piece of OSB:S. Here are a couple of products that I was thinking about using. The product from West Marine appears to have really good reviews, and has been used to rebuild transoms, and plywood floors. Seems like it would work well here.
    Rot Terminator from Lowe's
    Git Rot from West Marine
  • Looks like bottom had some dryrot even before it happen.
  • I think the injectable wood epoxy is the way to go. I'd sure hate to have to strip it apart to put new wood into it. Good luck, and hope you can get it fixed.
  • I'm sure some people here with experience with a similar repair will chime in, but that's not me. Good luck!
