4x4ord
Jul 10, 2019Explorer III
Lynnmor wrote:
So what is this thing?
They want us to believe it is similar to a "big rig" engine brake. It is more effective than a standard exhaust brake but it is still nothing like a jake brake. If you think of an engine as an air pump you can imagine how restricting the exhaust raises the pressure at which the volume of air is being pumped at and creates more braking. Downshifting speeds the engine up which causes the engine to pump more air which also creates more braking. The Packbake holds the exhaust valve off its seat during engine braking. So with the Pac brake the piston pushes air past the slightly opened exhaust valve causing braking on the compression stroke. The pressure on the piston would be equal to the exhaust back pressure created by the restriction at the turbo. The cylinder would refill through the slightly opened exhaust valve on the power stroke and then offer the same braking as a typical exhaust brake on the exhaust stroke. Again it is the power require to force the air past the turbo that is creating the braking.
A Jake brake uses a camshaft or hydraulic pressure to pop the exhaust valve open near top dead centre on the compression stroke preventing the energy in that compressed air from pushing down on the piston during the power stroke. The pressure on the top of the piston during the compression stroke is used to accomplish the engine braking and is much higher than the 60 psi or so that a PacBrake or typical exhaust brake utilize for braking.
44,071 PostsLatest Activity: Aug 30, 2026
