H2oSprt wrote:
Sport45 wrote:
Are you sure the whine is coming from the transmission and not the rear end?
I'm sure it not the rear end as it will whine if I'm in neutral and rev the engine. I'm open if you guys think it's something other than the trans.
Just for grins, pop the drive belt off and rev it up a time or three in neutral. If the wine goes away it's not the transmission.
I had a bad idler bearing in a '94 F-150 that made an annoying whine like that. Alternator bearings have a high pitch whine when they go out too.
