LEMIIExplorerSep 09, 2013Jayco 23B Mattress Issue - Unevenness2007 Jayco 23B. Two-piece mattress set up with the narrower piece having a built-in offset. When the bed is assembled, there seems to be some unevenness between two pieces that causes me to roll tow...Show More
popupcampingExplorerSep 09, 2013If you can take the mattress cover off and get down to the foam couldn't you shave off an inch with a serrated blade?
Related Contentjayco bunk mattress replacement???MattressesJayco air mattress helpUneven Dually tire wearUneven Bearing Temp
