LEMIIExplorerSep 09, 2013Jayco 23B Mattress Issue - Unevenness2007 Jayco 23B. Two-piece mattress set up with the narrower piece having a built-in offset. When the bed is assembled, there seems to be some unevenness between two pieces that causes me to roll tow...Show More
PadlinExplorerSep 17, 2013I believe Joann fabrics carries sheets of foam, might be worth a call if you have one locally.
Related Contentjayco bunk mattress replacement???MattressesJayco air mattress helpUneven Dually tire wearUneven Bearing Temp
