miltvill wrote:
Hitch up your TV to the TT. Measure the front wheel well of your TV to the ground and repeat for the rear wheel well of your TV. Then adjust your hitch until both readings are the same. Now you TV will be level with your TT hitched up. Probably not a big problem with a F350. Next measure the front of your TT to the ground and the rear of your TT to the ground. It should be level.
I like my TT one inch lower in the front. But that is just me. If the back of your TT is higher then the front, it may sway. Go on the internet for your manual to your hitch.
Ford says to adjust any weight distributing system to return the front measurement to 1/2" higher than an uncoupled truck. This is because the weight distribution is inherently heavier toward the rear axle when loaded and the truck is engineered for that.
