jdfish's avatar
jdfish
Jayco 33 RLDS towing
Need some assistance here please. I have a Jayco 33 RLDS TT that I have only towed twice. Both times it seemed to sway more than I would think it should. I have the weight dist. hitch and anti-sway control hooked up. The first time I towed it was with a 1/2 ton Chevy. Thinking the truck was too light, I went out and purchased a new F350 only to find out it swayed just as much!! Wife not happy:(I would be inclined to think that my load balance is off and tongue weight needs to be adjusted. Or is this something I am going to have to live with. I have no idea what I have for tongue weight or even how to calculate it. I spoke to another camper in our campground who has the same camper and he said his tows great. I measured eighteen inches from the ground to the bottom of he ball on his 3/4 ton. Any advise I can get is very much appreciated.
  • Various things can cause your sway issues. Could be one, could be a combination of several. Things to check:
    Trailer tongue weight should be at least 10 percent of loaded trailer weight. More, is better. Average is 12 - 13 percent. Not enough tongue weight, can cause sway.
    Check hitch ball height. Towing trailer nose up, can cause sway.
    Unbalanced or insufficient tire pressures, truck or trailer, can cause sway.
    Impropper set up of weight distribution hitch. If your hitch is not restoring sufficient weight, to front truck axles, subconcious hand movements on the steering wheel, can cause the trailer to wiggle.
    Not enough sway control. A single friction sway bar, is not enough for a 35 foot trailer.
    Overweight can cause issues. With F350, probably not your problem.
    Tire sidewall flex can cause issues. Also, probably not your problem.
    Bad roads and cross winds can cause some sway, but, not much you can do about these.
    Your owners manual (truck) should have a guide for checking hitch setup. It'll discuss taking truck and trailer to a level spot and doing various measurements while hitched and unhitched.
    CAT scale weights, would help to pinpoint possible problems. IE: tongue weight.
    You'll need three passes on the scales.
    Pass one -- truck and trailer hitched up as if you're going camping
    Pass two -- truck and trailer without weight distribution bars
    Pass three - truck alone
    Main items I would look at --- Tire pressure, tongue weight, ball height, and hitch set up. If you only have one sway bar, maybe add another.
  • I can see where the 1/2 ton would have sway issues with a long rig but a 1 ton is more than up to the task. No reference to which WD/SC hitch you currently have but the Reese Dual Cam or an Equal-i-zer properly set-up will keep that long rig from swaying excessively. Make sure you have plenty of tongue weight (approx. 15%) as without no matter which hitch you use it will sway.
  • That TT was probably too much weight for the prior half ton. However, I would recommend spending $15 at a CAT scale first. You will find out what your TW is (percentage is important) as well as how well the WDH is adjusted. Take 3 passes. Truck alone, truck with TT without WDH and truck with TT with WDH. A review of this thread may also be helpful.
    Do you have a WDH? Which one?
