ElBesoBlanco
Feb 16, 2014Explorer
GWolfe, the heat pump wont work with outside temps 30F or below. If I wanted heat then I need to use the furnace when temps drop below 30F. The thermostat works great in maintaining heat when furnace is in use. (The Cool Cat heat pump A/C is all operated on the easy to use thermostat)
The A/C works great, but I have yet to use it regularly as the Cool Cat fans are super efficient in cooling the interior if trying to escape the heat. I also run the Fantastic Fan in reverse to pull warm air out. My 2000W inverter generator can run this with no problem, if neccessary (not A/C). I have done 3 days with no power in 100 degree days using just the cool cat amd occasional battery charge with the generator. I now have portable solar panels that regenerate my battery power but still love the lightweight generator as back up.
The gear deck is awesome! I like being able to carry home the dirty stuff (bikes, motorcycles, equipment, etc without having to stow it inside or take up room in the truck bed (I haul my two large dogs in crates in the covered truck bed)
